Sharing cams from Wyze app on my Android device with an IOS Wyze user
Please, I need help from IOS users.
I have Wyze app installed on my Android devices. I also have 5 different Wyze cameras set up.
This is my issue:
I shared all cams with an Apple user, That user accepted the invite. That user used the same invite email and added on 2 IOS devices, So basically ending up with two IOS devices using the sane email shared invite.
That IOS user decided to lend one of the 2 IOS devices to a family member which does not have her own device, email address and Wyze account.
I decided to create the family member her own email address and Wyze account. Once this was achieved, I sent her the invite using the new email address I just created.
What I don’t know, why my invite is not being received to the Apple device like I always do between Androids’? Also, how to remove the accepted invite that won’t be needed on one of the two devices once the newly invite is reached.
Please help!
You share with an account, not a device. If the user uses 2 devices to view that account, then that is not unusual.
Also not unusual.
I’m guessing because they didn’t previously have a Wyze account? They are up and running, so they probably didn’t see a reason to do anything different.
You can delete the previous invite by going to Account tab > Sharing > [select user] > select camera > Edit pencil in upper right > Unselect camera > Update
Thank you @Newshound for your insight.
Yes, I got it now.
Thanks again for your help.
