Setup/Test Floodlight :floodlight_pro: Before Mounting
Had an extra one of these ($2) so snipped a side to power, setup and test the floodlight/cam before mounting outdoors.
One of these would work, too. :slight_smile:
I spliced an unused cord for setting up and testing floodlights. Used it 5 times already.
Cool. Which floodlight model(s) do you own? Catch any defects in pre-mount testing? :slight_smile:
What did you do with your ‘extra hand’ after install?
If I had five I might hang a retired cam mobile. :wink:
I have all 3 floodlight models; 2 V1s (one swapped out), 2 V2s and 2 pros.
By “hand” do you mean the "S’-shaped gadget used to temporarily hang the floodlight while wiring it up? If so, I kept one in my toolbox and threw away the others.
Yep. :slight_smile:
One of the first floodlight V1s I ordered was OK during my tests. In about a couple of days though, it started flashing intermittently, blinding my neighbors. I had to take out the ladder and uninstall it. Fortunately, the vendor (not Wyze) took it back and I got a full refund.
My v1 floodlight tested ok. Once installed, I found that, in the location I installed it (tight w/light spilling onto neighbors windows) eschewing PIR motion sensor triggering at 100% brightness, in favor of setting floods to 1% dusk-to-dawn, was the way to go. The v3 cam starlight sensor reads the near environment well at that level, and looking out a window with your actual eyes it is bright enough to see, which is what I want. :slight_smile:
Tested a Cam v3 Spotlight accessory in a light box recently. :slight_smile:
I bought three refurb through ebay Wyze Direct (official) and one had a bad cable which they replaced with a full kit post haste.
