Flood light, attached camera removal
Hello, I had trouble searching for this question. We bought a flood light and I wanted to set up the camera before having the entire flood light installed… I’m having trouble unplugging the camera from the flood light housing. Is the plug hard wired to it? I’m afraid to use pliers and warp the plastic plug, I’ve already left a slight impression on it already =(
Easiest thing to do, if you have not hooked up the flood light yet, is to get an extension cord with the plug on one side and wires on the other. Then simply use wire nuts to connect the flood light up and set it up.
I did this with 2 of them before actually installing.
Something like this:
Then you can test all aspects, setup the camera, set the lights to come on when needed and if you have the extension camera, set that up as well. When done, you can hook it up and as long as you have WiFi in the location, it should connect and just work
Ok thanks! I just wanted to check before I hulk out on it and rip something lol. I ended up using vicegrips to pull the bugger out… it was in there pretty good.
Also, thanks Spamoni4. Thats a really good idea, I may try that on our back porch!
That’s a good idea, just BE CAREFUL!! The exposed wires on the other end are super dangerous, and dont let them get too close too each other when plugged in.
Absolutely correct.
Do not try to hook up the wires if you have it plugged in, hook up the wires first, then plug it into the wall outlet.
Wize needs to do better here, i am seeing the same issues that most are, you cannot register the darn thing. Probably should have gone with the ring. I hav 3 rings, never an issue setting them up. I have numerous wyze cams and devices and have had issues with a few. The wyze cam floodlight sorry to say is a failure. Wize should follow ring on how to activate with regards to app and wifi registration. Scanning a QR code is just not the right way to do this. 30 years in IT, 9 years installing security cameras and panel, nvrs etc…
Cannot scan QR code even printed out as some have suggested, also tried while it was dark out to minimize glare nothing works. I guess I am going to have to try spamoni4 way of activation. Which is a very dangerous way to get rlthe camera activated in the app and on Wi-Fi.
