I can’t set up my Cam Pan on the same network that my phone is on. Also, please allow portal logins through the app.
I believe this is the best you can do with a portal for now.
You might find it helpful to disable mobile data while setting up the camera. I could not get Wyze bulbs to work otherwise.
Is your phone using 5.0Ghz Wifi?
The cameras only work on 2.4Ghz.
