Set keypad passcode
How do I set a passcode on sensor keypad
Welcome to the community. You will find a lot of help in the forums
you would do that through the app.
  • Go to your app and tap on Monitoring
  • Tap on Home Monitoring settings
  • Tap on Pin and Safe Word
  • Tap on Update PIN
  • Then select Update on the entry screen
  • enter your PIN
  • Tap on Update
thats it.
