My sensors go offline constantly and the only way to get them back is to remove the bridge and power cycle the camera which is impractical to do multiple time a day. Is there a fix for this? I’ve seen loads of other people with the same issue, are the sensors just useless?
Wyze is looking at the issue!
I’d also look around here:
The frustrating part about window/door sensors going off line is that there is no quick way to reboot the sensor besides taking it off the mount, and then deleting it and adding it back again…sigh. I have for two now that is offline for no reason.
Id contact Wyze if you’ve tried all the troubleshooting tips!
Update. It turned out to be a low power issue. I replaced the power cable and has been fine for a while. So if anyone is having issues make sure the cam has enough power for the bridge.
Hello i had the same problem with my 4 sensors, i solved for now just pushing the bridge button tree times, he flashing blue ans yellow after that everything coming back online.
Any new i will share again the final result.
