I have a pan cam (with microSD inserted which otherwise works perfectly) and 2 door sensors with instructions to turn on the camera if either of the door sensors are triggered. I get a notification that the door is open/closed. In the events area of the door sensors it shows when something opened or closed and has a picture of a camera presumably meaning a video was taken. In the main Events tab, there are events detailed as 00:12 Smart video alerts but when I select the event it tries to load the video but then says “the video clip doesn’t exist in the cloud or is still being uploaded. Please try again later” . When I started with the pan cam it had a microSD and so the cloud was never used. How can I fix this by either having the Smart video clip be stored on the microSD or on the cloud? Thanks!
Related topics
Topic | Replies | Views | Activity | |
Occasionally contact sensor or motion sensor will not trigger a smart video cloud clip | 1 | 364 | November 26, 2019 | |
No Sensor Based Video Recording since 1/1/2021 | 20 | 1719 | January 10, 2023 | |
Wyze Cam Pan V1 Not Recording when Contact Sensor Triggers | 4 | 380 | October 7, 2021 | |
Sensor+Camera+Video Linked | 9 | 1174 | July 25, 2019 | |
Event Notification For No Events? | 7 | 982 | May 29, 2020 |
