Sensor battery replacement
Replaced the battery in the sensor. The LED blink red twice. Then nothing happened. The appl still shows the sensor low battery and offline. Anyone can help?
Welcome to the Wyze community!
Try deleting and reinstalling the sensor in your Wyze app.
Try rebooting the camera with the bridge that controls that particular sense sensor. (Wait a few minutes… If sensor not updated… Then you may need to remove the bridge, reboot camera, then re-attach the bridge and wait a few…
What is the distance between your sensor and the bridge? How much metal between?
