Sense motion sensor offline
Well THAT would be a huge relief. Assuming it all works.
Just installed a new motion sensor, same thing. Works for a short time then goes offline
Wait for the new ones with required Wyze subscription. These are just junked by their software
Else change the software
Information for motion sensor offline
https://forums.wyze.com/search?expanded=true&q=motion%20sensor%20off%20line
Try rotating the sensor a quarter turn and test…repeat if needed.
I was having the same problem for weeks and decided to try and replace the cheap flat Cat6 cable that came with my Wyze Sense Hub with a known good cable. Since replacing the Cat 6 cable, my system has been online for over a week. Worth a try if you are having this issue…
This forum thread/topic is related to v1 motion sensors that wirelessly connect to a bridge plugged into the USB port in the back of a Wyze Cam v2.
