Sense Motion Detector Unresponsive
When taking the motion sensor out of the packaging I noticed that it was blinking red for each motion it detected. I assume that is normal.
When trying to pair with the bridge it would never ‘blink 3 times’ but it would keep registering motion with the red LED. I can feel the reset pin clicking whenever I insert the tool. After multiple attempts with no change in behavior I found the FAQ which says to remove the battery.
After removing/replacing the battery it will now just blink twice when the battery is first inserted and does not respond in any other visible manner. I even tried pairing it a couple more times just to make sure.
Any ideas out there as to what the double blink and then no response means?
Thanks!
After 0 communications on the support case I happened to be browsing and saw this bit of info:
It still doesn’t explain the behavior that is SUPPOSED to happen but in limited testing it seems to be working. Hopefully it will help and props to the original poster(s).
I have the same unresolved problem. It stopped working, I replaced the battery. I can not pair it to any of the bridges.
I noticed messing around with it, if I push in the pin 5 times it seems to put it in test mode. It blinks at every motion.
But it will not pair with the bridge.
And no response from support either.
