Im a little late to the party but I’m experiencing this too.
Sorry to hear that! I’d recommend contacting customer support if that’s still the case.
Pulling the bridge out and plugging it back in while the camera was powered up did the trick. All of my sensors connected back up.
Cool , glad you got it working
What do you mean pulling the bridge? I have two Wyze cams with solid yellow lights and will not connect or even setup!
“Pulling the bridge”
He means unplugging and plugglng the bridge back in to the back of the camera.
This won’t work of course unless this camera already has a solid blue light.
Chas
I’ve pulled my bridge, changed it to another camera, reset my camera and still all my sensors are not working and the bridge light is solid yellow. I’ve emailed and emailed Wyze, still no help.
Does anyone else have a suggestion?
Thanks
Sedoijo
The customer support team is not answering emails. Is there another way to contact them?
@sedoijo You can call support.
Wyze Customer Service
1 (206) 339-9646
Available Monday - Friday 5 am - 6 pm PT and Saturday 8 am - 4 pm PT
Thanks for fielding this, @StopICU33!
@sedoijo, I’d recommend the phone number StopICU33 gave you. But may I have your support ticket number so I can look into why you haven’t received a response yet?
I had the same problem with a bridge connected to a V2.
Work around I found was to remove the bridge from the camera, wait for a minute or so while the camera “stabilized” and had a solid blue light, plugged the bridge in.
Didn’t find this thread until I had worked about 8 hours on the problem and found the work around.
My guess is that the problem is due to lack of enough amperage to allow both camera and bridge to establish connections at the same time.
WYZE needs to provide an adapter with greater output.
I tried that as well multiple times. I even removed the sensors from my service. Removed the bridge from my camera for a day. Reset up everything. The same thing happened. The bridge works sporadically. I contacted Wyze and they helped me with the issue.
Hello,
Yes, that’s a standard fix as suggested by Wyze.
Troubleshoot the Wyze Sensors/Bridge
I have a 3A PS Powering the camera with the bridge.
Chas
Would be nice if WYZE made it easier to find that advice.
Would be nicer if the advice to use a more powerful power supply was included in the instructions packaged with the bridge.
Even nicer yet would be if WYZE included an adequate power supply when they ship the bridge.
and how did they solve the problem?
Im hoping Wyze will solve the problem as per my and others suggesting they use a “stand alone bridge”.
Instead of plugging the a bridge component into a camera, the bridge would become a stand alone unit… with improvements such as a larger internal wifi antenna and large antenna to send signals to the sensors. Better cooling of components. Higher amperage 5v power supply. Filters to smooth the 110vac and prevent surges.
Chas
After all the troubleshooting, Wyze is replacing my bridge at no charge.
I hope that solves your problem.
Chas
M too. Thanks. I’m waiting on the replacements. I’ll let everyone know what happens.
