Send video events to my pc
Is it possible to send a video event to my pc? I want to enlarge and analyze something my camera recorded.
You can share (Email videos) or download to your phone and send them to yourself via email, air drop or other means. If you are using bluestack on a PC you can down load that way also to the PC. Are you using iOS or Android. This is share, the other icon is download. You have to play the video to the end then you can share/download.
I download stuff to a synced google photo directory and then go into my Google photos on my PC and download whatever there.
Not sure I understand. I want to send the Wyze event video on my phone to my PC. Can this be done? And, are the events stored on my phone or in the cloud?
Thanks
David
Yes. If you go to events on the app. choose the video you want from the events page (Cloud Video), tap it and let it play until the end. If you just want to send it to your PC you have to send it via message, email, air drop and so on. That video is not saved on your phone in your photo video album. Share is the one I marked. If you play the video to the end and tap the icon to the right of share it will download to your photo album on your phone and it will be saved there. You still have to send it to yourself. I usually just use share so my phone/video album is not packed with the videos. Are you using iOS or Android?
Thank you for your assistance.
David
So did you try it and did it work ?. You can’t have a complete story without an ending :grin:
Like watching a blockbuster movie in the theater and having the power or something go out right before the ending. Ahh! Need closure. :laughing:
After a bit if fiddling around it worked.
Thanks
Finally got it to work. Thanks
I was only able to email one video from the event app. Now it keeps down loading like it’s stuck I cleared the cash. What do I need to do to send more to email
When you say “enlarge and analyze” do you have software on your PC to do this or do you just want to view the video on a bigger screen?
When I need to view video on a bigger screen I use my iPad Pro with a 12.9 inch screen. Most times I use the Wyze App in my Pixel phone which fits in my pocket.
How long is the video ? Which camera are you using? How good is the wifi signal at the camera? The video files from my V3 cams load very fast, the V3Pro and the V4 cam takes a little longer but they do load. If I want to send for than one video in a single email I just download the videos to my iPhone, select the videos and email. I think the limit is 25MB per email. For lager files I just send them to my Google drive then download.
