SD card size
I currently use this card with 256 of storage and it works perfectly in my V4 and V3. Can I use the 516 or 1TB?
“Officially” the v4 supports up to 512. I believe the older cams state 256 max, but others have had the 512s work fine in v3 and others. Not sure if anyone has tried 1TB in the old or newer cams, but probably will work if formatted to exFAT. Of course “YMMV” if you go above what the specs say.
To be honest, Team Group is pretty low end as far as SD cards go. If they’ve been working well for you, then worth a shot, but if you plan to record 24x7 I’d recommend an endurance rated card (also helps with extreme temperatures, moisture, etc). Samsung/Sandisk endurance cards have both proven very reliable.
