SD card capacity limit
Does this camera have a SD card capacity limit? Could I use a SD card with 64GB or higher?
V2 specs: Supports 8GB, 16GB and 32GB microSD cards in FAT32 format.
The Wyze spec is 32 GB, however many people are using larger cards. Personally all of my cameras are using 64GB cards. Likely the more important part is to use good quality cards that are designed for video operation. This is the card I’m using:
https://www.amazon.com/gp/product/B00V5Q1N1I/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
Are use these all the way up to 128 GB. The extreme is their top-of-the-line and for the extra money I figure it’s worth it so that I know that it’s gonna work. So I’ve use the 32 GB, 64 GB and now I’ve used 128 GB of this version in Wyze cameras
The endurance cards are a step below the extreme cards and have given some people issues just FYI
I have no issues with SanDisk 128GB High Endurance Video microSDXC cards
https://www.amazon.ca/dp/B07NY23WBG/ref=cm_sw_r_cp_api_i_b21DEbEJ5TW1F
