Sd card formatting
Sd cards will not format. Using 32 gb.
They will not format in the camera using the app? Does it say formatting and never finishes or the card is not recognized?
Says formatting and never finishes. Only a few. Some do format.
I have one V3 cam that does that on occasion, it seems like it never finishes but I just tap the back arrow then go back and check and it will say 0.0GB of 119.36.
Have you tried formatting using a computer? Do a Full format not a Quick format.
Yes it will. Mine does and has some em I bought them several years back.
Why would they make you take it out of the camera and put it in a bigger slot so it can fit the opening on your whatever u use. That’s just ridiculous.
It will format on your app while in your camera.
