Need a notification when an sd card failure has occurred. Similar to offline notification.
I was using an OG with a known bad SD card (would work as long as I formatted it every day) for a temporary use. I think I did get a device notification that it had failed when I forgot to format it one day, but I can’t remember for sure.
It does notify you when you load up the cam live view, but obviously it would be better to know proactively. Unfortunately I’ve thrown away that card so can’t test it.
Yes, I had an event that I needed to review, when I used the sd video from two diff cameras they claimed sd card problems. Luckily I had a view from a third camera. But no before hand indication of failure from either camera. My fault - I had not used high endurance sd cards in those cameras. Lesson learned.
Glad the third camera had you covered. Until Wyze adds a real alert, a quick monthly check works: open each cam’s Advanced Settings, go to Local Storage, and make sure it still shows the card capacity, then scrub back a day or two in Playback. If a card has dropped out, it usually shows no capacity or asks you to format, so you catch it before you actually need the footage.
