Scrub video?
Is it possible to scrub video recorded on the sd card?
Welcome @dougkitajima
You can format the card from the camera advanced area. But if you want to do a permanent deletion and scrubbing, you would need to remove the card and then utilize an app to do a true and secure wipe.
Oh, I was actually talking about when you can drag the time bar (scrub) and see the video updating in real time.
Not within the Wyze app.
my apologies, misunderstood.
No. There is a wishlist requesting this feature.
In the distant past, I used to put the SD card into a computer and load all the files into VLC media player and I could then do video scrubbing on that to zoom forward and backward. It was awesome.
It didn’t work that way the last time I tried, but I am absolutely confident there have to be other programs out there that will automatically chain together the small videos into one timeline.
you can scrub on ios but only saved videos
but i believe scrub means more than this
at least wirh cam plus it should be possible to scrub for faces or vehicles, animals
