Scheduling and automation adds same rule for ALL cameras
I have 2 PanCams and 2 WyzeCams. I added a “Restart Camera” rule for my Garage camera (WyzeCam). It adds the rule for ALL the cameras. For example, if I launch my Kitchen Cam, (PanCam), the same rule is listed for that camera.
Somehow, I don’t think this is right. Any suggestions/thoughts?
No, it doesn’t.
It’s a presentation bug. Each rule still applies to the device you have set it up for, originally. Drill in by tapping each rule, and you’ll see the device being affected by that rule.
Wyze is currently preoccupied with security concerns. Bug fixing seems to have taken the back burner, for example, the SD card playback has been problematic since the last app update. That was a long time ago.
qlang243,
I figured it out. It threw me a bit to see the same rule for all the cameras. But after dinking around with the various cameras I see that even though the rule is displayed for all cameras, you still need to add each specific camera separately.
Seems like a goofy way to do it, you’d think they’d all be independent and not display every other camera’s rule.
Thanks for your reply.
