I set a schedule for my Wyze V2 camera to record from 10:00AM - 11:00PM. Since I am using a SD card for local storage, do I need to set it to ‘Record on event’ or ‘Continuous Recording’?
Are you on the beta app or the regular app from the App Store/Play Store?
The SD records as long as the device is turned on. The settings you are seeing are most likely for events. Can you post a screenshot?
Events are separate. It’s either continuous recording, event recording, or nothing to the SD card. The first screenshot is for the cloud events. Loki made a post last week that may help clear things up.
Okay so my only option is continuous if I don’t want to only record motion?
For the SD card yes. @Loki, please correct me if I am wrong.
Thanks for your quick response!
No problem. I have asked Loki as well to verify that it is in fact true.
Correct. For the SD card, if you want to record more than motion, then you must use continuous. As stated above, this has nothing to do with the 12-second motion/sound/smoke/CO clip recording to the cloud.
