Schedule for color light bulb
Hello, newbe here. I look on YouTube to figure out to put a schedule on my color light bulb. I do not seem to have the same setting as the exemple on the video. I want the light to open every day at the same time and off at the same time. Do you do this by creating a rule ? On the video, it had a schedule option but I don’t. My firware is up to date. Thanks for any feedback.
Yes, click the plus on the corner, then add rule, then schedule, put on your times and click add action and select your bulb and what you want it to do.
Thanks John, so if I have 3 light bulbs in the house, do I create 3 different rules ?
You can if you want them to be on different schedules or you can create a group and tell the rule to schedule the group instead of one single bulb
Super ! Much appreciated !
So first click the + and then do add device group and add your bulbs to it. Then create the rule with your schedule. The action you would select the group you created.
Glad to be of service and happy lighting!!
