Scheduling Color Bulb 2
Schedule rule to turn a bulb on and then off. Do I create a separate rule for “on” and another for “off,” or, can I create a single rule and check the “on” and “off” options?
You can do either. It’s easier to manage one schedule though. When making one schedule to turn on/off, do not add “Off” as an action. It’s already implied as your end time (see note at bottom of example). This example turns bulb on at 11 minutes after sunset with brightness @ 54% and color purple… and automatically off at 9 minutes before sunrise. Schedule runs every day of the week:
Thank you.
