Scale Weight History
How can I see weight history longer than a year? Maybe this is not an option.
You have to export the data and view it in a spreadsheet instead of in the app.
Open Scale
Go to settings.
Select “Export Data”
Enter Email address
Select “All”
Select “Export”
Check your SPAM folder, mine got filtered to my SPAM folder.
It will look like this:
Mine went all the way back to the day I started in April 2020.
You can also use that data to import it into another app or program easily, but the Wyze app only shows the last year’s worth of data there…but your data is still stored in the server.
Thank you.
