I got the Lo message on my Scale S and started taking out batteries to replace them, but the 3rd battery was stuck in the scale.
It took about 15 mins with a pliers to work it out of the slot.
This seems like a design flaw.
Was that battery swollen? That is usually what causes that. The obvious way to tell is if the replacement battery goes in easily, the old battery was swollen.
It appears that the wrapping around the battery got caught on the plastic casing where it slides into the slot, so when I tried pulling it out it was ripping away at the battery label, causing friction and excess width.
Same exact problem. Gonna try pliers next.
Same problem. Very frustrating. The more I try, the more it gets stuck. Spent half an hour trying.
Same problem. First time replacing batteries. Now it’s too late to return this junk.
Just happened to me; any recommendations to get it out pliers are not able to grab it.
I haven’t had any luck. I gave up after an hour. The scale was $25. Not worth my time trying to fix this stupid issue. Has anyone tried reaching out to wyze customer service?
I just did; waiting on a warranty decision.
Add 1 more to the count. But I did get it out. I took a small pocket knife, got the point stuck into the battery, with handle it at a low angle and just started tapping the end of the knife and was able to knock it out. And yes, the new battery went in with no trouble. The stuck battery was one of the originals that came with the scale, of the other two, one would move freely while the other would stick.
They sent a new scale
Same problem here. A design flaw and/or poor quality batteries included with the scale. They lasted a year for me, but they clearly swelled.
@jim78457
I am sorry this happened. I would recommend calling support about this when you can.
(206) 339-9646
Mon - Fri 4am - 8pm PT
Sat - Sun 8am - 4pm PT
I would call support about this and see what they can do.
(206) 339-9646
Genius
