After about a year of faithful service, my scale batteries finally died. After I replaced the batteries, the scale will no longer display any activity on the device, will no longer connect to my phone. I have reseated all the batteries, checked the connectors, removed/replaced them. I do not see any external switches/buttons/toggles to manipulate on the device.
Help! I now have a stylish yet utterly useless brick on my bathroom floor.
My scale worked fine after I replaced batteries last month, and I didn’t have to do anything special. Sounds like you did some great basic troubleshooting already.
Call Support, they will have a script in place telling them about all the known issues with the scale and how to fix them:
By phone: (206) 339-9646 Available Monday - Friday 5 am - 6 pm PT and Saturday 8 am - 4 pm PT
Or online: Wyze.com/support
I’ve called them about issues before and they have frequently given me other ideas to try that I never thought of.
I called support today after almost a year and a half of having my scale, The scale started to read LO on the screen… so I waited a couple days and then changed the batteries out. At that point nothing came back on the screen on my scale was blank. I hit the restart button in the back nothing …I got another set of batteries even though the first pair I put in was already fresh to see if that might be a problem, nothing no light nothing but darkness on the scale …put the batteries in the different direction just to make sure I wasn’t going crazy again nothing …Support said they were not able to help me or exchange my unit. Very disappointed.
same happened to me. definitely a defect. My scale actually died before the battery did this made it look like it was a battery problem but it wasn’t. I took the batteries out left them out for a minute put them back in and then the scale worked a month later the scale died again. I took the batteries out and put it in a new pair and the scale worked one time when I stepped on it flashed the low battery sign and then died again.junk.
Mine was doing the same thing changed batteries 3 different times and still nothing while reading this forum I turned my scale to the back again and just started pressing on the little feet in the bottom and when I turned it around it started working again it went to 0.0 I guess for some reason that reset it
It’s the 2 little sponges that level the scale down I pressed the 2 top ones
