Scale graph should reflect all weight measurements taken in a day
Can we please update the graphs so they show all measurements taken in a day?
Right now Wyze only shows a day’s most recent measurement in its graph. If I weigh myself five times throughout a day, I will get five different measurements, but only the most recent shows in the graph.
So if I weigh 182 in the morning, 180 at noon, and 186 before bed, the graph only shows 186, not all values, which are actually really valuable data.
I know all data shows in the list view but I would like to see it in the graph view.
2 posts were merged into an existing topic: Wyze Scale - Historical Trends for All Values
Just a reminder my original request that started this topic is for Wyze app to graph every measurement of body fat and weight, not just the most recent one.
Subsequent replies are talking about graphing multiple other factors the scale detects but that’s totally different than what I’m talking about. I’m all for this request, too, but I’d like to gain support for my original request here.
Sorry! Thanks for letting me know. I merged the other posts into the other wishlist item to avoid confusion.
Is there any way I can edit my original post? I don’t think it expresses what I’m asking for as well as I’d like it to. Should I just delete and repost instead?
did you try to edit the post? if you can’t, then just post what you want on a reply and I can change it for you.
Thank you!
There’s no mechanism to edit.
Original post might be more effective if it were to say:
Subject: Scale graph should reflect all weight measurements taken in a day, not just the most recent one
Body:
I updated it for you! I shortened the subject title though.
Perfect - thanks!
I would like to have the ability to have an AM and PM reading saved to the app for each user.
You can look at the history to see all the weights for all users for the primary account holder. It just doesn’t show all the weights on the trend graph.
I can see the weights in Trend graph, but no history. If I weigh myself in the AM, then weigh myself in the PM the AM weight is over written.
@joel7 - that is odd. I usually weigh in around three times a day (a habit I picked up from testing the thing in the beginning) and I get all readings in the history. Just the trend graph shows the latest reading.
Have you kept up with the Firmware and App updates, and are you using any of the Beta testing apps?
I believe I have the latest firmware and I am on the BETA app which is up to date. On ios, and don’t see a history tab or icon. Where’s the history?
I thought it was overwritten at first too. You have to click on trend as seen here. There is no history tab or icon. I feel that they should make it more visible which would be a good wish list idea. That’s how it works on Android at least…
Yes, I see that! But for my purposes I want the one in the morning (AM) to be in the trend chart, and the others showing in History is great. So what is happening is that the last measurement shows in trend and the others are in history. Would be nice to be able to set the measurement you want to be in trend. Does that make sense?
Yes that makes sense… Maybe adjust your topic to be able to manually designate the weight listed in the trend graph.
I will say, related to this wishlist, that the only time ever weigh myself more than once in a day is when the weight gets logged, but the body measurements fail. This seems to happen more often when my heels get calluses or when the batteries get low. Sometimes I can get my feet wet to help or grab a nearby towel rack and push myself down harder for the electricity to catch better…but there are times I have like 7 of the same weight measured in 1 day just because the first 6 wouldn’t register the body measurements.
If this wishlist gets implemented, I would hope that it would take something like that into account to not skew the data too much. Maybe there could be a separate graph that would take each measurement like requested here, and another that would simply average out all measurements in the same day and use that average for that day. Then it wouldn’t skew things up if there are an abnormal amount of measurements on some days and one 1 on other days.
