Wyze Scale - Multiple weight readings in a single day
Hello - I received my wzye scale. I’m curious if it can store multiple weight readings in one day. Seems to do so for the heart rate reading but not the weight reading. It would be helpful if you could upgrade the UI to do so please. Thanks, Steve
You can store multiple weight values in the same day. Are they not showing up?
I found it. Was looking for something a bit more elegant on the dashboard, but the data is available. I’m sure it will improve over time, and maybe they can add the ability to download a csv. Best, Steve
