Scale duplicated profiles
I have an OG scale. A couple of months ago, an update forced me to start having the app open to have it update my phone with the scale data because it was confused that it was the same person using the scale.
I just bought a Scale Ultra to try and get around the problem, but now I see there are 6 of the same profile listed. The wizards (idiots) tell me profiles cannot be combined and reduced to a single profile. That is complete BS; someone just does not care. SQL is not a difficult language. I am guessing hacking into Wyze can’t be that difficult from what I’ve seen of their software problems. Is this a solution I should resort to in order to correct this simple software problem, or has anyone actually gotten anywhere with these numbskulls?
Exact same issue for me. I am using the Android App with a Wyze Scale X. I have dozens of identical profiles in the app that I didn’t create. There is no data or history in any of them but the first one I made.
How can I fix without manually deleting all of them?
Same issue here.
Exact same issue with my Wyze X
Anyone found a fix to this issue? It’s kinda annoying.
