I cannot get my Wyze Color Bulb rule to turn on my bulb from the schedule I created. Although it does turn the bulb off according to the schedule rule. Anyone else having this problem?
Can you post a picture of your rule? what is your start and end time for the rules? There is a issue which I posted after testing my scheduled, where some scheduled rules are delayed by 2 to 5 minutes before the actually work. Seems to happen on the top of the hour. Mine was at 10pm. I moved it back 1 minute and it worked.
My rule on-time was set for 8:00PM and off was set for 6:15AM. Thanks for your suggestion … I now have set my on-time for 7:59PM. See if that works.
