Rule interaction
Being a newbie, I hope you will excuse me if this is old. I have a camera with SD card recording motion as it happens. I also set a rule to turn on/off the same camera with door sensor open/close. So of course there is a conflict- when the door is closed it turns the camera off. Is there a solution or is it one rule per camera etc? Thanks, Rodney
If you want that, since the camera is only “on” when the door is open, just set the camera to continuous record.
