I’m trying to create a rule. I want my camera to turn on, upload a short video to cloud, turn on motion detection and turn on notifications when a door opens that has a sensor on it. So after I hit save I get a loading notifications continuously running and the rule never saves. What am I doing wrong? Do I have to set the camera up a certain way? Please Help.
Do you want that all active only when the door is open? What do you actually want to happen when the door opens? In simple terms, do you want a video saved when the door opens? Do you want a video saved and a notification when the door opens?
That’s alot to happen as a result of the door opening, especially if you are trying to turn on a camera after a door is opened and instantly get a video of motion and a notification.
I’m assuming you’ve installed beta for Androind Try uninstalling and reinstalling.
Worked like a charm. Thank you very much for your help.
