Rtsp v2
I cant get the RTSP firware working. I magically got it to work on one camera but on cam 2 when i hold down setup button it goes to blinking orange and asks me to setup again.
Try removing your SD card, if you have one, and power cycling your cam.
If that fails, try a Factory Reset . And then Reflash YourFirmware .
If that fails, call in the big guns at Wyze Support
Best of luck - keep us posted!
Are you holding the setup button during power cycle? It needs to be pressed when power is applied.
Yes I am. I somehow got the second one working but the process IMO is not straight forward.
