RTSP for v3 and Pan v3
Had to kill notifications in Beta 738 app, false snow persons and snow pets detections, lighting changes are persons, drifting blowing snow is person, driving me bonkers. SMH
Well, last ditch effort is, Frigate 17 Beta 1. Got all 5 cams streaming again.
Changed out the Frigate+ Mobilenet model for the community built, Yolo version for Coral USB etc. supported in Frigate 17 Beta 1.
Time will tell.
The community Yolo for Coral didn’t detect for me. Fell back to Frigate+ Mobilenet. Working again so far…might try Yolo again once some bugs are cleaned out of it.
I cannot get it to work in frigate whatsoever… works in app but in frigate I just can’t get it to work.
The really old v3 firmware works no problem in frigate…
Click ask ai at Frigate, bottom right on on a phone anyhow, drop in your config and see what it suggest or try the same with Grok or GPT for assistance. It was a trip getting it working here with Pan V3s for me.
What does you config look like? The old V3 firmware works fine on RTSP but this new firmware won’t work in frigate, no idea what’s going on.
It seems best to flash with a 32gb card for some reason. Fat32 format, only the Wyze firmware on it. In case it matters. I turn off record to SD myself or it writes junk on the SD on boot.
Anyhow, latest working config below. Mine is plugged into HAOS via MQTT, Frigate is running in the Ubuntu Host in Docker.
mqtt:
enabled: true
host:
user: mqtt-user
password:
go2rtc:
streams:
reolink_sub:
  - rtsp://admin:<password>@<reolink-ip>:554/Preview_01_sub
reolink_main:
  - rtsp://admin:<password>@<reolink-ip>:554/Preview_01_main
reolink2_sub:
  - rtsp://admin:<password>@<reolink2-ip>:554/Preview_01_sub
reolink2_main:
  - rtsp://admin:<password>@<reolink2-ip>:554/Preview_01_main
wyze_pan_v3:
  - ffmpeg:rtsp://<wyze-username>:<wyze-password>@<wyze-ip>:554/stream0#video=copy#audio=opus#audio=pcma
wyze_pan_v3_2:
wyze_pan_v3_3:
ffmpeg:
hwaccel_args: preset-vaapi # keeps 4K recording on the iGPU
output_args:
detect: -threads 3 -f rawvideo -pix_fmt yuv420p
detectors:
coral:
type: edgetpu
device: usb
\# model section removed - no Plus license needed for basic detection
cameras:
# EXISTING REOLINK CAMERA — NOW FIXED
reolink_4k:
ffmpeg:
  inputs:
    - path: rtsp://127.0.0.1:8554/reolink_sub
      input_args: -rtsp_transport tcp
      roles:
        - detect
      hwaccel_args: -c:v h264_qsv -hwaccel none   # ← CPU decode for detect only
    - path: rtsp://127.0.0.1:8554/reolink_main
      roles:
        - record
        \# inherits global preset-vaapi → stays on GPU
detect:
  enabled: true
  width: 320
  height: 320
  fps: 5
  stationary:
    interval: 50
    threshold: 50
objects:
  track:
    - person
    - car
    - cat
    - dog
  filters:
    person:
      min_score: 0.5
      threshold: 0.7
    car:
      min_score: 0.25
      threshold: 0.30
      min_area: 250
    cat:
      min_score: 0.7
      threshold: 0.8
    dog:
      min_score: 0.5
      threshold: 0.7
motion:
  threshold: 20
  contour_area: 5
  improve_contrast: true
  mask:
    - 0,0,0,0.455,0.43,0.419,0.428,0.355,0.763,0.35,0.592,0
    - 0.773,0.407,0.757,0.354,0.48,0.358,0.51,0.408
    - 0.001,0.457,0.002,0.519,0.443,0.458,0.425,0.445,0.427,0.423
    - 0.782,-0.001,0.771,1,1,1,0.993,0
    - 0.309,0.785,0.252,0.527,0.448,0.497,0.453,0.717,0.401,0.793
zones:
  Deck_Person_Zone:
    coordinates:
      0.769,0.555,0.72,0.549,0.675,0.65,0.324,0.698,0,0.863,0.006,1,0.731,1,0.767,0.644
    loitering_time: 0
    objects:
      - cat
      - dog
      - person
    inertia: 1
  car_in_lane:
    coordinates: 0.433,0.412,0.476,0.409,0.77,0.438,0.767,0.551,0.48,0.469
    inertia: 1
    loitering_time: 0
    friendly_name: Car in Lane
review:
  alerts:
    required_zones:
      - Deck_Person_Zone
      - car_in_lane
# NEW REOLINK CAMERA #2 — NOW FIXED
reolink_4k_2:
ffmpeg:
  inputs:
    - path: rtsp://127.0.0.1:8554/reolink2_sub
      roles:
        - detect
    - path: rtsp://127.0.0.1:8554/reolink2_main
      roles:
        - record
detect:
  enabled: true
  width: 320
  height: 320
  fps: 5
objects:
  track:
    - person
  mask: 0.952,0.148,0.626,0.596,0.706,0.919,0.987,0.877
  filters:
    person: {}
motion:
  mask:
    - 0.001,0.236,0.001,0.62,0.05,0.629,0.067,0.278
    - 0.294,0.442,0.281,0.682,0.377,0.683,0.381,0.502
    - 0.271,0.015,0.271,0.088,0.695,0.089,0.695,0.012
wyze_pan_v3:
ffmpeg:
  inputs:
    - path: rtsp://127.0.0.1:8554/wyze_pan_v3
      roles:
        - detect
        - record
      input_args: preset-rtsp-restream          # crucial
detect:
  width: 320
  height: 320
  fps: 5
objects:
  track:
    - person
  filters:
    person:
      min_score: 0.1
      threshold: 0.2
    car:
      mask: 0.115,0.574,0.049,1,0.892,1,0.766,0.65
motion:
  threshold: 25
  contour_area: 5
  mask: 0.721,0.929,0.724,0.983,0.984,0.987,0.979,0.928
wyze_pan_v3_2:
ffmpeg:
  inputs:
    - path: rtsp://127.0.0.1:8554/wyze_pan_v3_2
      roles:
        - detect
        - record
detect:
  width: 320
  height: 320
  fps: 5
objects:
  track:
    - person
  filters:
    person:
      min_score: 0.3
      threshold: 0.5
  mask:
    0.91,0.074,1,0.077,0.995,0.994,0.369,0.988,0.502,0.838,0.597,0.753,0.73,0.778,0.839,0.678,0.891,0.591,0.906,0.392
motion:
  threshold: 20
  contour_area: 5
  mask: 0.723,0.938,0.725,0.985,0.98,0.981,0.972,0.925
wyze_pan_v3_3:
ffmpeg:
  inputs:
    - path: rtsp://127.0.0.1:8554/wyze_pan_v3_3
      roles:
        - detect
        - record
detect:
  width: 320
  height: 320
  fps: 5
objects:
  track:
    - person
  filters:
    person:
      min_score: 0.4
      threshold: 0.65
  mask: 0.867,0.497,0.949,0.499,0.951,0.612,0.864,0.621
motion:
  threshold: 20
  contour_area: 5
  mask: 0.721,0.977,0.981,0.982,0.977,0.934,0.716,0.929
# Everything below stays unchanged
record:
enabled: true
alerts:
pre_capture: 10
post_capture: 7
retain:
  days: 3
  mode: active_objects
detections:
pre_capture: 10
post_capture: 7
retain:
  days: 3
  mode: motion
snapshots:
enabled: true
timestamp: true
bounding_box: true
clean_copy: true
retain:
default: 3
detect:
enabled: true
version: 0.17-0
And without formatting. I guess not forum formatted anyhow. lol
mqtt:
enabled: true
host:
user: mqtt-user
password:
go2rtc:
streams:
reolink_sub:
reolink_main:
reolink2_sub:
reolink2_main:
wyze_pan_v3:
wyze_pan_v3_2:
wyze_pan_v3_3:
ffmpeg:
output_args:
detectors:
coral:
type: edgetpu
device: usb
cameras:
reolink_4k:
ffmpeg:
  inputs:
      roles:
        - detect
      roles:
        - record
detect:
  enabled: true
  width: 320
  height: 320
  fps: 5
  stationary:
    interval: 50
    threshold: 50
objects:
  track:
    - person
    - car
    - cat
    - dog
  filters:
    person:
      min_score: 0.5
      threshold: 0.7
    car:
      min_score: 0.25
      threshold: 0.30
      min_area: 250
    cat:
      min_score: 0.7
      threshold: 0.8
    dog:
      min_score: 0.5
      threshold: 0.7
motion:
  threshold: 20
  contour_area: 5
  mask:
zones:
  Deck_Person_Zone:
    coordinates:
    loitering_time: 0
    objects:
      - cat
      - dog
      - person
    inertia: 1
  car_in_lane:
    inertia: 1
    loitering_time: 0
review:
  alerts:
    required_zones:
      - Deck_Person_Zone
      - car_in_lane
reolink_4k_2:
ffmpeg:
  inputs:
      roles:
        - detect
      roles:
        - record
detect:
  enabled: true
  width: 320
  height: 320
  fps: 5
objects:
  track:
    - person
  filters:
    person: {}
motion:
  mask:
wyze_pan_v3:
ffmpeg:
  inputs:
      roles:
        - detect
        - record
detect:
  width: 320
  height: 320
  fps: 5
objects:
  track:
    - person
  filters:
    person:
      min_score: 0.1
      threshold: 0.2
    car:
motion:
  threshold: 25
  contour_area: 5
wyze_pan_v3_2:
ffmpeg:
  inputs:
      roles:
        - detect
        - record
detect:
  width: 320
  height: 320
  fps: 5
objects:
  track:
    - person
  filters:
    person:
      min_score: 0.3
      threshold: 0.5
  mask:
motion:
  threshold: 20
  contour_area: 5
wyze_pan_v3_3:
ffmpeg:
  inputs:
      roles:
        - detect
        - record
detect:
  width: 320
  height: 320
  fps: 5
objects:
  track:
    - person
  filters:
    person:
      min_score: 0.4
      threshold: 0.65
motion:
  threshold: 20
  contour_area: 5
record:
enabled: true
alerts:
pre_capture: 10
post_capture: 7
retain:
  days: 3
detections:
pre_capture: 10
post_capture: 7
retain:
  days: 3
  mode: motion
snapshots:
enabled: true
timestamp: true
bounding_box: true
clean_copy: true
retain:
default: 3
detect:
enabled: true
version: 0.17-0
This is my config, other cameras are V3s with older RTSP firmware that was pulled and they work no problem, the “luna” camera is the new one on the new RTSP firmware and it just won’t play on frigate, I’ve confirmed it works on VLC it’s just Frigate it won’t play it.
# yaml-language-server: $schema=http://ccab4aaf-frigate:5000/api/config/schema
genai:
enabled: true
provider: gemini
api_key: ----
model: gemini-1.5-flash
object_prompts:
person: Examine the main person in these images. What are they doing and
what might their actions suggest about their intent (e.g., approaching a
door, leaving an area, standing still)? Do not describe the surroundings
or static details. Make it humorous and a little bit condescending, maybe
add some Italian humour in there as well. Make sure to make it a short
description. Finally don't start every single description with "Oh,
honey." please.
car: Observe the primary vehicle in these images. Focus on its movement,
direction, or purpose (e.g., parking, approaching, circling). If it's a
delivery vehicle, mention the company. Make it a little bit humorous and
condescending and make sure to make the description short.
mqtt:
enabled: true
host: 192.168.2.176
user: mqtt
password: mqtt
port: 1883
topic_prefix: frigate
stats_interval: 60
go2rtc:
streams:
porch:
      - rtsp://admin:admin@192.168.2.35/live
      - ffmpeg:porch#audio=aac#audio=opus
driveway:
      - rtsp://admin:admin@192.168.2.36/live
      - ffmpeg:driveway#audio=aac#audio=opus
garage:
      - rtsp://admin:admin@192.168.2.37/live
      - ffmpeg:garage#audio=aac#audio=opus
luna:
      - rtsp://admin:PASSWORD@192.168.2.237:554/stream0
      - ffmpeg:luna#audio=aac#audio=opus
# - input_args: -rtsp_transport tcp -timeout 5000000
webrtc:
candidates:
      - 192.168.2.176:8555
      - stun:8555
logger:
# Optional: default log level (default: shown below)
default: info
# Optional: module by module log level configuration
logs:
frigate.mqtt: error
frigate.app: error
frigate.edgetpu: error
detectors:
coral:
type: edgetpu
device: usb
cameras:
porch:
genai:
enabled: true # <- enable GenAI for your camera
objects:
        - person
required_zones:
        - porch_deck
        - porch_stairs
ffmpeg:
inputs:
# - path: rtsp://admin:admin@192.168.2.44/live
        - path: rtsp://127.0.0.1:8554/porch
roles:
            - detect
            - record
detect:
width: 1920
height: 1080
fps: 5
objects:
track:
        - person
        - dog
motion:
improve_contrast: 'true'
mask:
        - 0.839,0.678,0.877,0.449,0.899,0.281,0.909,0,1,0,1,1,0.77,1
        - 0,0.261,0,0.544,0.397,0.226,0.376,0,0,0
        - 0.255,0.513,0.259,0.656,0.191,0.734,0.098,0.571,0.159,0.41
        - 0.394,0.371,0.465,0.751,0.409,0.82,0.233,0.754,0.256,0.374
        - 0.296,1,0.267,0.923,0.086,0.778,0.06,0.84,0.1,1
        - 0.547,0.624,0.439,0.592,0.413,0.804,0.536,0.807
threshold: 35
contour_area: 8
zones:
porch_deck:
coordinates:
0.304,1,0.387,0.839,0.432,0.817,0.494,0.821,0.544,0.822,0.552,0.703,0.704,0.63,0.77,0.8,0.722,1
objects:
          - person
          - dog
filters:
person:
threshold: 0.80
dog:
threshold: 0.81
inertia: 2
loitering_time: 0
porch_stairs:
coordinates:
0.3,0.784,0.365,0.811,0.291,0.953,0.256,0.897,0.196,0.861,0.254,0.773
objects: person
filters:
person:
threshold: 0.81
inertia: 3
loitering_time: 0
record:
enabled: true
retain:
days: 2
mode: all
alerts:
retain:
days: 7
pre_capture: 5
post_capture: 10
detections:
retain:
days: 2
snapshots:
enabled: true
bounding_box: true
crop: false
timestamp: false
retain:
default: 7
required_zones:
        - porch_deck
        - porch_stairs
mqtt:
# Optional: draw bounding box on the snapshots (default: shown below)
bounding_box: true
# Optional: crop the snapshot (default: shown below)
crop: false
enabled: true
review:
alerts:
required_zones:
          - porch_deck
          - porch_stairs
detections:
required_zones:
          - porch_deck
          - porch_stairs
driveway:
genai:
objects:
        - person
        - car
required_zones:
        - driveway_path
        - driveway_pavement
ffmpeg:
inputs:
# - path: rtsp://admin:admin@192.168.2.30/live
        - path: rtsp://127.0.0.1:8554/driveway
roles:
            - detect
            - record
detect:
width: 1920
height: 1080
fps: 5
objects:
track:
        - person
        - car
filters:
car:
threshold: 0.79
mask: 0,1,0,0,0.993,0,1,1,0.84,1,0.789,0.555,0.324,0.594,0.3,1
person:
mask: 0,0,0,0,1,0,1,1,0.862,1,0.802,0.53,0.315,0.555,0.279,1,0,1
threshold: 0.80
motion:
mask:
        - 0.355,0,0,0,0,1,0.248,1
        - 0.24,1,0.273,0.56,0.803,0.512,0.877,1,1,1,1,0,0,0,0,1
threshold: 35
contour_area: 10
zones:
driveway_path:
coordinates: 904,1080,827,398,567,402,457,1080
objects:
          - person
#          - dog
#          - cat
filters:
person:
threshold: 0.81
#          dog:
#            threshold: 0.8
#          cat:
#            threshold: 0.8
driveway_pavement:
coordinates: 1656,1080,1660,1005,1755,997,1495,427,817,431,864,1080
objects:
          - person
#          - dog
#          - cat
filters:
person:
threshold: 0.80
#          dog:
#            threshold: 0.8
#          cat:
#            threshold: 0.8
driveway_car:
coordinates: 0.459,0.596,0.776,0.569,0.816,0.817,0.691,0.917,0.48,0.906
objects: car
filters:
car:
threshold: 0.7
inertia: 10
loitering_time: 0
record:
enabled: true
retain:
days: 2
mode: all
alerts:
retain:
days: 7
pre_capture: 5
post_capture: 10
detections:
retain:
days: 2
snapshots:
enabled: true
timestamp: false
bounding_box: true
crop: false
retain:
default: 7
required_zones:
        - driveway_pavement
        - driveway_path
        - driveway_car
mqtt:
bounding_box: true
crop: false
enabled: true
review:
alerts:
required_zones:
          - driveway_pavement
          - driveway_path
          - driveway_car
detections:
required_zones:
          - driveway_path
          - driveway_pavement
          - driveway_car
garage:
genai:
enabled: false # <- enable GenAI for your camera
ffmpeg:
inputs:
# - path: rtsp://admin:admin@192.168.2.37/live
        - path: rtsp://127.0.0.1:8554/garage
roles:
            - detect
            - record
detect:
width: 1920
height: 1080
fps: 5
objects:
track:
        - person
        - dog
        - car
motion:
mask:
        - 0.374,0,0.328,0.231,0.314,0.495,0.321,1,0,1,0,0
        - 0.327,0.226,0.324,0.315,0.573,0.322,0.586,0.136,0.602,0,0.374,0
        - 0,0.932,0.402,0.962,0.53,0.948,0.644,0.895,0.805,0.782,0.95,0.642,1,0.696,1,1,0,1
        - 1,0.581,1,0.68,0.951,0.63,0.882,0.695,0.747,0.4,0.59,0.159,0.602,0,1,0
zones:
garage_floor:
coordinates:
0.33,0.94,0.545,0.926,0.773,0.788,0.699,0.599,0.592,0.331,0.334,0.331,0.326,0.569
objects:
          - person
          - dog
filters:
person:
threshold: 0.76
dog:
threshold: 0.79
inertia: 2
loitering_time: 0
garage_car:
coordinates: 0.641,0.482,0.706,0.688,0.352,0.719,0.347,0.479
objects: car
filters:
car:
threshold: 0.75
inertia: 3
loitering_time: 0
record:
enabled: true
retain:
days: 2
mode: all
alerts:
retain:
days: 7
pre_capture: 5
post_capture: 10
detections:
retain:
days: 2
snapshots:
enabled: true
timestamp: false
bounding_box: true
crop: false
retain:
default: 7
required_zones:
        - garage_car
        - garage_floor
mqtt:
bounding_box: true
crop: false
enabled: true
review:
alerts:
required_zones:
          - garage_car
          - garage_floor
luna:
genai:
ffmpeg:
inputs:
        - path: rtsp://127.0.0.1:8554/luna
# input_args: -rtsp_transport tcp -timeout 5000000
roles:
            - detect
            - record
detect:
width: 1920
height: 1080
fps: 5
objects:
track:
        - mouse
# - person
# - dog
filters:
# dog:
#   threshold: 0.7
mouse:
threshold: 0.7
person:
threshold: 0.8
#    motion:
#      mask:
#        - 1252,720,1242,671,1100,665,1100,720
record:
enabled: true
retain:
days: 2
mode: all
alerts:
retain:
days: 7
pre_capture: 5
post_capture: 10
detections:
retain:
days: 7
pre_capture: 5
post_capture: 10
snapshots:
enabled: true
bounding_box: true
crop: false
timestamp: false
retain:
default: 7
mqtt:
bounding_box: true
#       crop: false
#       enabled: true
version: 0.16-0
camera_groups: {}
semantic_search:
enabled: true
reindex: false
model_size: small
detect:
enabled: true
Ok may have gotten it working now… removing the “ffmpeg” part seems to have fixed it..
ffmpeg:luna#audio=aac#audio=opusis what I removed it provided sound for all the other V3s but guess the new firmware doesn’t like that, looks like the firmware just provides sound without that!
Even with the half decent config I posted, as with many, if not all RTSP WiFi Frigate configurations, they are somewhat notorious for leaky or flaky RTSP. Seems especially the 3 Pan Cams.
So almost every day the logs in Frigate starts throwing errors. They’re still streaming, just that Frigate isn’t happy or me.
I’ve looked at my Mesh WiFi, but it is old for reports and adjustments. Nothing to see there much.
I’ve added all Wyze cameras to power cycle in HAOS every day with smart plugs, even before RTSP.
And I added an HAOS restart every day for the two recent addons, Reolink WiFi cameras, though they are fairly clean amd happy in the logs.
Time will tell, my Mesh is wireless backhaul, may change that down the road if these changes above don’t help much. Or upgrade the Mesh to modern.
Still searching for other solutions, besides POE, can’t climb ladders and crawl around in the attic anymore to run Ethernet cables.
Do the cams have a main stream and a sub stream, or is stream0 the only one?
rtsp://<wyze-username>:<wyze-password>@<wyze-ip>:554/stream1
Is the low-res sub stream. Just add a 1 in place of the 0
Cool, they should add that to the RTSP app cuz it only tells you about the 1 main stream. @ Wyze employees…
@WyzeEric @WyzeDave Any updates on timelines for when this firmware will be pushed out so we don’t need to flash the cameras ourselves? Any updates when this will hit the main app vs beta? Really any updates on official channels and any tentative timelines would be appreciated.
Got 3 of my old V3s set up with this new firmware. They were all working perfect in Blue Iris, I blocked them from accessing the internet and everything was working for about an hour before they all disconnected at the same time. I unblocked one and it came back online right away. Is internet connection required for this firmware?
I would love this, shocked they don’t do it via the RTSP App Beta anyways, were using a diff app, it should not be overly hard to add it via that. I can’t access my camera’s outside till at least late spring now.
Following
@WyzeDave @WyzeEric yeah same here, I Setup the Pan V3 with the beta firmware and using Wyze beta app, Getting Error Code -36 and when trying to setup RTSP its Failing to save credentials. - Using android with a galaxy S20 Ultra phone
Just trying to help a little.
If you’re using the standard Beta app you’ll get error 36. Need RTSP app and hotfix for access to flashed cams.
Hotfix for RTSP app is for creds issue either in this thread above or in this one, I’d post links if I had them saved, but I don’t. RTSP BETA RELEASE FOR v3 and Pan v3! - #333 by G2740
