Rooms for Wyze vacuum
I got the vacuum and it’s awesome! But it set my whole house to “room1” and I can’t change it or set other rooms.
Anyone know how to do this?
I’ve noticed this if you have an open concept design or if your rooms are open on two sides. One trick I’ve had luck with is placing physical barriers, like closing one of doors, so the room has only one entry point. The latest beta sw and fw have some new tools to make this easier. Quick mapping makes it much easier to reset the map and start over if you don’t like the current mapping. Also a map editor will let you split large rooms. They are working well and should roll out in an upcoming release soon.
