Received our Wyze Robot Vacuum yesterday & did the room mapping. When it was done I had a few problems.
Picture one is of our Guest Bedroom as you can see the mapping assigned it 3 room numbers it is only one room.
The second picture is Master bedroom mapping did the same thing assigned 3 rooms when only one.
Third picture Kitchen is really 4 rooms Kitchen Dining Room Living Room & Family Room but mapping only assigned 1 room.
My question is how do I delete the extra rooms that were not needed & add 3 rooms that were needed?
Again first time users so we will probably have many questions.
Mike
Pencil icon on the middle right side of the main screen, then select “Customize rooms”. You can then merge/split as needed.
Thanks it worked.
Mike
