Room customization crash (iOS beta 3.5)
After the most recent beta update, when I attempt to customize a room for the vacuum, the app immediately crashes.
This happens whether the phone has been up for a while or just reset, and even after a quick mapping run.
I have sent crash logs each time it has happened.
I have downgraded back to the most recent 3.4 version and all is well for now.
Now, with the most recent beta, the crashing issue has been resolved.
However, when attempting to pan and zoom on my floorplan, the map seems locked to only moving certain directions and will not stay focused on the part of the floor plan I want. It snaps back to the center of the floorplan after I stop touching the screen.
I have send feedback via the appropriate iOS app as well.
I’ve got the same problem when zooming (2 finger spread) in the floor plan it snaps to the left portion and locks there. It makes it impossible to set no-go zones on the right side of a floor map.
