After the initial run on the robot vacuum there is slender section behind a bed and a room behind a closed door that wasn’t mapped. I can’t find a way to add these sections. Help is appreciated.
To my knowledge the only way currently to add these rooms is to provide physical access by opening doors, clearing obstacles to access, etc. and resetting the map. Then run again to create a new map.
Thanks. Well that stinks! Needs to be on the top of the feature wish list.
I sent this suggestion in a while ago too. For areas of my office where we move furniture or have the fold out walls, the vacuum has no idea what to do about it.
Things like this are one of the main reasons in beta there is currently a map only feature where the vacuum isn’t running it is just running the outer perimeter wall and doing a map only of every room I can. it works much quicker and uses only a few percentage points of the battery. it’s far easier to update the map using this. I noticed you aren’t in beta but I wanted to mention it anyway so as to give you hope for a quicker feature in how to map In such instances
Bam makes a good point about the new quick mapping feature but it also has the drawback of being less accurate. I’ve done the quick mapping several times and each time, there is an area of the office the vacuum misses. We really need the ability to start an area remap or something similar.
I lost count of how many times I reset the map and started from scratch but I have a solid map now and I’m holding it tight! It took a lot of time over several days to get it done well.
Seems like it wouldn’t be all that hard programmatically to have the vacuum provide the user with a few options after having discovered a new room while running on an old map, something like this:
WARNING: New area detected.
- Add new area to current map and save
- Add new area to current map and save as a New map
- Ignore new area in regards to mapping
Try running a quick remap with the door open and no obstacles blocking the slender section. If that doesn’t work, you might need to reset the map and let it scan everything again.
