Robot vacuum backup until it loses connection
Wyze needs to update the firmware on there robot vacuum. Anytime I have to mess with it or move it to a different room, the minute it touches the docking station and says charging it slowly starts backing up until it loses connection. I have to stand there and repeatedly move it so it will connect to the docking station without moving backwards. I don’t understand why it does this and the other day it did it returning to charge and finally the battery died because it kept pushing back on the docking station until the connection was lost and I wasn’t there to babysit it. Please tell me I’m not the only one having this issue and that there is a fix out there
What is your current Firmware being used?
Is it an Original Wyze purchased Vacuum or one from Walmart?
There are a number of threads about firmware on the Robot-Vacuum.
You can go here to see the versions: https://support.wyze.com/hc/en-us/articles/360024852172-Release-Notes-Firmware#Accordion-walmart-wyze-robot-vacuum-firmware-59
1.6.313 and originally bought from wyze website. I was more saying Wyze needs to make a new firmware update to fix the problem if no one had a solution
