Ribbon Cables for v2 and V3 and v4
Does anyone happen to know the model of the ribbon cables used in the V2, V3 and V4 cameras.
I found one post that looked promising, but alas, it went no where.
I am looking to see if I can get a little bit of a longer cable to extend the board away from each other for a project. Any help would be greatly appreciated.
I ordered this one and it works just fine with my Cam v4. 2 Pack 13.1FT Power Extension Cable. It also came with the clips that worked out great! You can find 20’ and 30’ versions of the same brand.
I could be misinterpreting the request, but I believe @john.viragrow is asking about the ribbon cables that connect the internal PCBs:
If you don’t want to void the warranty on your own camera, then it’s easy to find disassembly/teardown videos on YouTube that illustrate the internal hardware.
I don’t have an answer to the question, but welcome to the Forum, @john.viragrow! :wave:
Ya I looked on youtube, but did not really find any specs. Figured I would try here
