Reverting firmware
Why isn’t there a setting anymore to revert the firmware of my devices? I’m having all sorts of issues and there is no way to downgrade.
You can load any version of firmware that you want. You use a uSD card and do the manual flash procedure. A quick search here will come up with the firmware files and procedure.
Thought reverting was only a beta program feature.
No. You can use the uSD card flash method to load ANY firmware version at any time.
That’s not what I meant. My understanding is that beta program participants have had a firmware rollback feature in the GUI and that that is what the poster is now missing.
You can remove yourself from the beta program from the GUI.
I’m a beta tester. And the option “having trouble” isn’t there anymore.
Seems like common sense to leave that option available for everyone.
Now I have 3 cameras that are part of my security system not working at all. They just keep clicking and trying to spin all the way around.
