That was a very nice way to be able to revert, now I just tried to revert a camera and there are no choices. So I’ll have to do the SD card dance with the 0.28 version.
I don’t think it has disappeared. I added a vote to your suggestion.
I think it’s only available when there is an upgrade firmware available. If your fw is already on the latest update them it just says"your firmware is up to date!" and shows the app version. Then you can’t click on the have a problem button to get to the firmware versions to downgrade to. This is what I’ve seen on the non beta app.
I think the revert to earlier firmware should be an option when you have the latest firmware… Not just when you have an older firmware.
Nevermind, like you said in another post… They did take it away. Thanks.
