Does anyone know if there will be a update in the app for the feature of resting your wifi connection bc I got a new wifi router and it’s hard to climb up and get the camera down to reset the wifi
There is a current wishlist requesting the ability to change the wifi information without a device reset. Visit to vote if you want to support.
In the meantime, you’ll need to either do the initial setup again or change your new wifi network info to reflect what the old wifi was and then the cameras should connect.
Where in the app do I change my wifi?
Change wifi info on a camera/device? Or change your router setup? Need more if as to what your wanting
If you want to change the wifi information for a camera, don’t delete the device, just click the + in the upper left of the home page if the app and the setup the camera again using the new information.
