RESOLVED: DNS Setting for Mesh Pro
I’m trying to setup Pihole running on a raspberry pi. Chatted with wyze support and was told there is no way to edit the DNS routing on their product. Is that true? Has anyone successfully setup Pihole using a Mesh pro?
Not really.
Go to the router and click on the gear at the top right. Then go to advance followed by ip address.
Select LAN IP and switch to manual. From there you can enter your own DNS IP address.
CRAZY, you would think their support would know the product.
Thank you!
@kpctoy
I am sorry that happened, were you given a ticket number so I can make sure they are using the proper information?
Wyze Ticket 3000446
Thank you
