I got an older camera out that has been sitting for almost a year. I plug it in, red status light comes on but it will not go into set-up mode, nor will it hard reset by holding set up button for 20 seconds. Is it bricked? Wyze cam OG v3 i believe
Not necessarily bricked. After sitting that long I’d swap the USB cable and wall adapter first; a weak supply can leave a red light on while SETUP does nothing. Then unplug for a minute, hold SETUP, plug back in while still holding, and keep holding past 20 seconds until you get the setup voice/prompt.
