Reset lock bolt stuck in “Wyze lock bolt not found” during BT setup
My lock bolt battery was low and I changed to new batteries. No response from the lock bolt so I tried to reset the device to see if that helps. Now after press “ pairing” my iPhone cannot find the lock and it is always showing “not lock bolt found” message. Tried everything force quit, log out, taking out batteries overnight and still no luck. Let me know if anyone else faced similar issue. Thanks !
I just encountered the same problem. After repeated efforts, I disconnected my phone from wifi, made sure I had a data connection and of course that bluetooth was on and then it worked.
