Replacement for Wyze Video Doorbell Pro
I’m looking to replace my doorbell Pro. Is there an upgrade or a newer version?
I’m running wired.
I see the Battery Video Doorbell and the Video Doorbell V2. Which would be better?
Thanks.
The vdb v2 if you want wired and want to use your house chime or you may want to consider the duo video doorbell and use your house chime or the included wifi chime if you buy one that includes it.
Are the notification issues resolved? I always had problems with the old one.
Resolved with respect to which device and notifications? Push notifications to phone? Specific notifications?
Push notifications. I was never able to get them to work. I worked with support for a time, but finally gave up.
No issues with my backdoor duo but my front doorbell duo does not push notifications consistently. Luckily I have a v4 as a front porch cam that makes up for it. I’m still tweaking the detecton sensitivity in hopes that I’ll solve the deficiency and get it working. Both were purchased and activated at the same time.
