My professional cameras that were installed have the following power requirements:
110 volt in 12 volt out 5000mA
Wyze has:
Power Adapter Input 110-240V (AC/DC)
Power Adapter Output 5V/1000mA
The problem is the output. Is there a converter or someway that I can adapt it to 12 V and then just install them in the exact same spots where the so-called professional cameras are installed and already have power and Wi-Fi.
Once again you’re correct I was thinking that the USB see was what was connecting into the camera but that is what connects into the power supply that plugs into the wall so I would need the different end thank you for correcting me on that
This has been a fun discussion. I talked to the guy that did the so-called professional installation of the cameras that I have about what I was wanting to do and he’s not real happy about it. He also believes that wired is always going to be the future and the Wi-Fi cameras are not going to progress and get better and be the future. I think it’s because we live in a rural area where Wi-Fi is sometimes sketchy but they’ve improved it immensely lately so I think he’s going to find out that more and more people are going to want to go Wi-Fi and his expensive $200 wired cameras aren’t going to be selling. I showed him a picture of my $20 wise camera at 1080P and he said that was a pretty decent picture. I said that’s a great picture for a $20 camera at 1080P. And he said well our cameras now are 2160P and I said but they’re also $250 so I’m not sure I want to pay 10 times the amount for slight difference in picture quality.
Your right, straight would work better. Only thing I’d be concerned about would be If the non-wyze micro would fit in the recess hole of the camera. You might be better off with a female USB connector like this.
I think both have their place. Hardwired cams can link up to a central NVR and aren’t as easily knocked out with WiFi interference ( natural or intentional). Wyze packs a ton of value in these little boxes, but better sensors, lenses, & build quality do have value.
That being said, a $20 camera this good is just awesome!
The female USB accepts the standard Wyze USB micro cable supplied in the box,. By using that cable, you know it’ll fit the camera. Sometimes the plastic shroud on cheaper micro USB cables is much larger than the sleek/skinny shroud on oem cables.
Zjed. Yes yes yes that is very correct and it would give me extra cable so I could move it a little bit if I needed to very very good choice again thank you for your help and advice this is been an awesome discussion
