Cam V2 or V3? If V2, was it hard opening the case to flip the UART switch?
Good to repurpose.
I would have thrown mine away.
I suggest dropping it off to the county hazardous waste disposal. Or ask the local high school if they want them.
Or give them to @gemniii .
I just found this out and will ditch all my 8 cameras for a more expensive brand. Good luck Wyze!
V2 does not require opening the case to install Thingino firmware. The firmware can be installed using an SD card. I used the 32GB Wyze card that had been in the camera.
What I read from the instructions say that you have to flip a UART switch inside the V2. V3, you need not open.
