Hi, I just got my camera and have a couple questions. First, do I need a SD card for continuous recording without having the app open and doing manual recording?
And second, is there a way to install the app on Amazon fire tablet?
Welcome to Wyze World.
The answer to your first question is yes, exactly.
I believe people have been able to side-load the app on fire tablets. The Alexa integration may work on them too (I’m not sure). If you search for “fire tablet” here on the forum, I’m sure you’ll find some good info.
As for the Fire - YES!!
And with the new multiscreen on my Fire 10 it’s GREAT.
I’ll try and find the instructions.
Thanks for your help!
link
Plus now I can use most all android apps
