Record to MicroSD Automation Option
I think it would be handy to have the ability to setup an Automation that can either manually be triggered or Automatically be triggered so that when a Battery Cam Pro detects that it is only running on battery power to switch the recording from Continuous to Events Only.
Currently when the power goes out for an extended period of time, I manually go to each camera and switch the setting to save on power for however long it may be out. Worse case a few days during a hurricane. Then I have to switch them back to continuous once power has been restored.
I don’t think this would be too hard to give us access to.
This seems kind of like two separate requests:
  1. An Automations Trigger that executes if/when Battery Cam Pro determines that external power is lost. (An Action “that can…manually be triggered” would just be a Shortcut Automation.)
  2. An Automations Action that can switch microSD card recording mode.
The second is an existing request in this Wishlist topic:
The first I haven’t seen specifically requested elsewhere but probably belongs in this related topic:
One of the requests in that second topic seems like it’s headed in that direction or at least adjacent:
If you haven’t already done so, you can visit those topics, click or tap the Vote button above the initial post, and share your ideas and use cases in the comments.
