I still like convenience over efficiency.
I still use a toaster oven. Now that is inefficient.
You can find mini UPS power banks on Amazon for under $40. Talentcell is one brand. They have 12V input and both 12v and 5V USB output. The 12v is true UPS, the 5V is not but your camera will power cycle back up quickly. I have 2 cameras connected to 1 UPS power bank with a Y cable.
Itās critical to add a battery pack option for Wyze cam pan
I would like to see a Wyze battery backup power solution that integrates with the app. I have most of my WyzeCams on UPS, but this is wasteful, as basically having a battery without an inverter is all that is required. Yes there are mobile phone chargers that can also power the WyzeCam, but many donāt act like a UPS (they either charge themselves or power the USB, but not both). Even the ones that do are less than ideal, as I would definitely like to know if one of my WyzeCams loses AC power and is running on battery power.
I could see having a battery option built into the WyzeCam as a good solution, except for those of use who already own a gaggle of these thingsā¦
It would be a great improvement for your product if you could create a battery pack that the camera could run on in the event of a power outage or by someone simply turning off the power.
Hmmmā¦that got me thinking. Iām no electronics expert, but Iām wondering if this reboot couldn;t be prevented within the camera by using either an internal capacitor that provides power momentarily during the switchover, or a small internal backup battery (like a digital clock would have to maintain time during a brownout). I bought a new Keurig a few months ago, and it has such a feature where it maintains the time and settings in case of a momentary power failure (my old Keurig would lose the time and some settings). I understand that a Wyze Cam is not a Keurig, but the Keurigs seem to be designed and constructed much more cheaply with each generation, yet they added this. How hard or costly would it be for Wyze to do this in V3?
Importance of power backup: If the power and internet go down and the power reinstates and the internet stays off the cameras will not record until the internet returns. This is also true for my other cameras. My internet router is on a UPS but that doesnāt stop the external internet from failing. One solution a power bank for each camera
Any chance you guys are working on a UPS? A small one would be great.
I use the battery from my drone with a usb converter to make my cam completely portable.
Rechargeable emergency battery backup to keep the camera recording in event of power outage (could be caused by someone cutting power before break in).
A battery pack could be backwards compatible, could self charge when power restored, and in event of outage could provide a few hours recording, may be it could through a tweak of firmware force the camera to record continuously to Sd card if the wifi had also suffered power outage, and maybe signal an alert through the cellular network or transmit the live footage to cloud through cellular ?
Battery Backup for Wyze Cam3
Hi - I have several Wyze Cameras and I was looking to power them by the Micro-USB with a battery box that acts like a UPS - ON all the time - fed power from Micro-USB and outputs to Micro-USB⦠I have tried several cell-phone battery boxes, but they shut off or will not charge when outputting power. Does anyone know of a device that does this so the cameras can continue to record to their memory card even when power or network is down?
[Mod Note]: Your request was merged to this topic for consistency in grouping similar requests. Please remember to scroll up to the top and click the VOTE button. You may also wish to comment on and/or vote for On-camera backup power supply/battery.
I would also like to see a (1) Wyze power bank with pass through charging to work as an UPS or to plug into a solar panel via USB as a solar solution -OR- (2) a solar panel with an integrated battery to be able to power v3/non-outdoor cameras with solar. The second might be a bit of a stretch as the panel would have to be larger than the current Wyze solar panel for the Outdoor cams. However the power bank would be great because it could be used in a number of configurations. DC fast charging would be idea to be able to plug into an external AC adapter to an outlet OR plug into an alternative power source such as a solar panel for an all DC setup. Fast charging would be a must to be able to recharge the power bank quickly, especially in a solar setup.
Built-In Battery Backup of All Cameras
In the event the power goes out, it would be great if future models of all cameras had brief battery backups. Itās nice to have a battery back up on a wireless router, but impossible per-camera. If the cameras could sustain at least 20-30 minutes of operation from an internal battery, it would be nice for power blips or in the event someone unplugs the camera thinking they are getting away with something by doing so.
The beast of all battery backup setups ![]()
VOLTIC - I finally found a USB power battery pack that is always on - I have not purchased one yet, but feel free to check them out:
Pat.
Create a Battery power box with multiple USB outputs to run several cameras
Mod Note: Merged topic. These comments will be taken into account during review. Please make sure to VOTE at the top.
Camera Battery
Device: Camera Battery
Description: Continuously power your Wyze Camera during a power outage, outdoors, or on the go. When plugged into a power outlet the camera battery will constantly power your Wyze Camera and when there is a power outage the battery will switch to battery power without interruption like their larger cousins called uninterruptible power supply uninterruptible power supply (UPS).
Support: All existing and future Micro USB and Type C powered Wyze Cameras.
Power Type: Continuously.
Pros:
* Uninterrupted Camera recording.
* Portable power.
* Increased camera locations outside of Wifi.
Cons:
* More expensive.
* Can catch fire if handled incorrectly.
* Limited to powering once camera only
[Mod Note]: Your topic was merged to this Wishlist request for better visibility and consistency in grouping similar requests. Please remember to scroll up to the top and click the VOTE button to show your support. You may also wish to comment on and/or vote for Ideas for a Wyze portable power station / battery backup with solar charging.
